Thread Tools
Old 03-09-2015   #1
Question drivers window stuck
After driving home in my fiat punto today, when closing the drivers window the window would not go up. The two front windows are electronic and the passenger side works fine however when i try and put the drivers window up it makes a horrid crunching noise and doesn't move. I've had to try and pull the window up but it wont go any further than half way.
Has this happened to anybody else? Any advice would be appreciated
kclegg23 is offline Reply With Quote Quote
Old 03-09-2015   #2
Ben D has donated!
Re: drivers window stuck
Take the door card off and have a look, check the guides on either drivers door lock or changing front speakers, these will show you all the screw locations. When I changed my drivers door lock, there is a bit of plastic that sits inside the door (for reasons unknown to me) which is held in place with 2 serrated flange nuts. Mine was missing a nut and the remaining one was almost off, if that had come completely loose I'm sure it could have interfered with the operation of the window. This is just a guess though!
Door card comes off in about 5 minutes max, got to be worth a look.
Ben
06 Grande Punto 1.4 8v daily and T-Jet toy
Ben D is offline Reply With Quote Quote
Old 03-09-2015   #3
Sounds to me like the window regulator cable has broken, dead easy to replace if it is, just take off the door panel and a few nuts and a clip later it's out! Hope this is of some help
JohnE76 is offline Reply With Quote Quote
Old 03-09-2015   #4
Trader Rating: 1
petercresswell has donated!
petercresswell is an honorary friend of the forum :)
Smile Re: drivers window stuck
Quote Originally Posted by JohnE76 View Post
I agree with John 76. My Panda did similar with the same horrid noises. For once I had an extended warranty that covered them both. You can get the parts on the net for about 40 and as already said it is not a difficult job if you take it steady and exercise patience!!
Good luck
petercresswell is offline Reply With Quote Quote
Old 05-09-2015   #5
JimbbobW1977 has donated!
Mine snapped once easy to do... Next to break will be the wires in the door so you will have no power to the windows......
JimbbobW1977 is offline Reply With Quote Quote
Old 1 Week Ago   #6
My drives side door electric window has broken. I took the door panel off and the metal wire inside is messed up. Is this easy to fix
Scott
Sent from my iPad
Scottdole92 is offline Reply With Quote Quote
Thread Tools
(G) Window stuck xander_trippin Bravo / Brava 4 08-10-2008 09:50
(T) Help electric window stuck down!!!!! stmterrace Multipla 8 10-06-2008 17:12
(G) Help! drivers electric window stuck wringerbay Bravo / Brava 4 27-05-2008 22:29
(T) Window Stuck Down cdjl123 Cinquecento / Seicento 2 18-11-2006 17:59
Drivers Seat Stuck Please Help Steve FIAT Boo Archives 5 24-08-2006 14:09
