- Jan 29, 2009
- 64
- 19
Hi all
Been a while since I have posted so hopefully I am in the right place.
Bit of advice needed about going about replacing a seat airbag on my 06 Grande. I have searched and seem to be getting differing info.
Basically the airbag located in the drivers seat airbag has gone off as a result of an accident. (I bought it like this) I am trying to work out if replacing the airbag unit alone is all thats needed or will I need to replace the ecu aswell. Can the original ecu not be re set using a hand held scanner type tool. The breakers I have just called suggest I need airbag, ecu and the sensor from the front panel and have quoted me over a ton for these !!
Any help much appreciated.
Mossley Puntos
Mossley Puntos
