Hi All,
I'll be due new tyres in the next month or two so going to change track rod ends, and lower arms. Slight knock from OS balljoint, may as well do NS at same time and TRE's are an easy job when its in bits and makes sense to do before alignment which I'll get when I fit tyres. Car is 06 reg with 59,000 on it and I think all parts are original so probably about time.
Anyone know what size, thread & grade the bolts holding the arms to the subframe are and what size the ball joint pinch bolts are? From past experience, makes sense to have spares before I start.
Thanks in advance
Ben
Thanks in advance
Ben
