Hi All,
I returned to my 08 plate Grande Punto 1.2 at the station last night, and turned the ignition key - and nothing!! The only sound was from the radio. Dash lights came on - with the immobilser light remaining illuminated.
Breakdown guy thought it was a key fault, but after running diagnostics it detected an ECU fault, and said Key was OK. Couldn't get me started so recovered to home. Have now arranged for a garage to look at it tomorrow, and will need recovery to take me there.
I always used to get the car serviced/repaired near my old workplace, and trusted that garage - however due to redundancy I have changed jobs and they are now over 30 miles away. Using a new garage locally now and just wondered if anyone on here had any hints & tips of what it could be so I am armed with a bit of knowledge - forgive stereotyping but as a female get worried I might get ripped off!
Breakdown report says (if I read his writing correctly!)
No cam message from ECM:
-BC/ABS report "U" codes for ECM
-Key OK
-EC relay has no switches earth signal from ECM
-Fuses OK
-Relays OK
After driving 50 miles round trip to work everyday for 9 years, car is on 94500 miles. But now I have a new job I commute by train so car is rarely driven now apart from short trips at weekends - hence repair not urgent and dont want to spend a fortune on it (relative to its value)
Any advice greatly appreciated
Many thanks
-Key OK
-Fuses OK
-Relays OK
Many thanks
