I've got a problem with my car at the moment, if I drive the car normally all is good if I give the accelerator a good kick after about 30 secs I get loads of blue smoke, so I know it's oil it's burning and I'm thinking valve seals, It happens aswell if I go down hill in gear for a long time and then accelerate at the bottom it puffs out smoke, done a compression test and had 120 psi on all 4 cylinders and the people I know who used to work for fiat said that's fine. When I drive normal the turbo is still boosting but no smoke. Does anyone share the same outcome as me with the valve seals or something else?
