Nope they are Defo the right ones so don't worry. Right well start with back they are easier. Wheels off, undo damper at bottom, drop axle down (push it down with foot), pull spring out, pull back arch lining (need to take some screws out of it I think) or something like that, undo top mount of damper from car and then take rear damper top mount off original damper and put on new ones. Attach adjuster cups at the top, keep the rubber inserts from the old rear springs, put the bottom rubber seat on the rear spring and top of spring sits around the cup. Adjuster cups and held in with bolts you can get to by pulling back wheel arch, use jack to jack rear axle back up so bottom damper holes line up. Can't remember where I put axle stands but don't put them somewhere that it won't let rear axle drop fully down to get spring out. Right so for the fronts I recommend buying spring compressors from eBay they are like £10. This is because you have to take the top mount off the original spring to put on joms. So front struts, take wheel off, undo relevant bolts at bottom that meets hub/front axle (whatever it's name is), whenever undoing bolts of advise use lube and lots of leverage( long bar) if you don't have access the impact wrench. So you've removed bolts from hub or whatever, Pop bonnet, undo screws from scuttle panel (plastic bit) to access top mount. You need spanner (not socket) because you have to put an Allen key in the middle, undo top mount and strut should come out, you will have to remove brake line and/or sensor from original strut (it's held on with a rubber mount of some sort. Anyway you have strut out now, here comes the most difficult bit. So it's quite unsafe to do it the way I did it, which was slacken top mount of old strut off to as much as I dare and kick the top mount round until it shoots off and spring flies off over my fence into next door! A lot easier to compress springs using spring compressors and take top mount off. Put old top mount on new joms. Attach top mount to car first by inserting strut up into scuttle panel bit and secure there, attach at bottom, it's worth nothing that don't just put bolts in and tighten up. You can alter camber on front by pulling hub upwards and tightening up, or vice versa pulling it down for opposite way camber. Just pull it up and push it down and roughly find middle and tighten bolts up there at bottom, ensuring all lines/sensor cables or whatever are secure. Make sure everything's tigtjened up. Use lots of grease, this means then if you ever need to change anything/take it off then it's lots easier. Think I forgot about undoing drop links on front which required socket and spanner behind it I think. You'll see how to undo that (can't quite remember how). Don't think I've missed anything. Hope that helps. If you have any questions then please ask me and ill try help. Set adjusters to middle front and back then to adjust just jack car up and wind threads up or down.
