General Battery Problems.
Hi
The other day my grande Punto took awhile to start, also a few weeks back the milage on the screen started to flash. Are these signs I need a new battery?
I believe the current battery is the original which makes it 7 years old.
I phone Fiat today asking for a price for a new battery, they told me they sell 2 batteries for my car one which is 40 something amp and the other 80 something amp. Ranging between £60 - £80.
Which size amp would I need for my car?
My car is Fiat Grande Punto 1.2 petrol 5 door 2008
Do you think Fiat would charge me to fit the new battery and dispose the old one?
Also is £60 for a new battery a good price?
Many Thanks.
hi,
need more info..??
battery rating depends on your car, and the kit on it,
biggest is Stop/start
then Clutchless gearbox ("automatic")- Dualogic..,
aircon maybe..,
40 Amps sounds TINY..!!
TBH put your reg into europarts site,, and post a link to the battery it recommends ; - ),
Charlie
202 is the size /description standard.
here is the Euro range
http://www.eurocarparts.com/202-car-batteries
Bosch S4 is excellent value,
tip - enter Bosch S4 202 into Ebay - Europarts have several accounts ( carparts4less,etc)
you may well find a great deal AND local collection OR free delivery
bought my older punto batteries this way..!!
Charlie
Would you recommend Bosch, Duracell or a genuine Fiat Battery?
Many Thanks.
TBH ,
BOSCH S4(y)
the FIAT will be an o.k. battery with a FIAT cover.., :rolleyes:
the Duracell MAY be better,??never seen one on a car before:eek:
sure it'd be good in a VW golf ( "rabbit") :D:rolleyes: LOL,:ROFLMAO:
Charlie
EDIT - it's your money, buy what you want..,
BUT- the Bosch has the better ,established, reputation AND is probably the cheapest..
Okay thank you.
If I order one from euro parts how do I fit the battery and what do I do with my current battery?
Many Thanks.
battery changing is simple..:) BUT potentially hazardous-so well done for asking..,Safety glasses / some eye protection is a GOOD IDEA- as some risk of arcing..,
familiarise yourself with YOUR car's battery connections + layout - youtube guides may help too;)
unlock car, undo + support bonnet, put key in your pocket..!!(y)
you undo the BLACK "earth cable" and swing away from battery- battery is now SAFE as there is no "circuit",
undo RED positive cable, and swing away( put plastic bag / tape over - to ensure it';s insulated,
then use a socket to undo the CLAMP - down the side of battery ; - )
battery can now be lifted out of car--IT'S HEAVY..!!:(
wipe out bottom of battery tray, access is good..,(y)
put new battery in ( same direction)
fit clamp to side ( fiddly):(
then refit RED cable to + symbol positive battery pole / terminal, and tighten;)
then BLACK to - = negative terminal ( you have remade the circuit) = so may get a minor spark + clunk from electronic devices.., normal..!!
wait a second.. if all seems fine,
walk to cabin, put key in ign, turn to 1st stage , check lights come on dash,
if good, turn back off and then tighten battery clamps fully,
now start engine - should be fine
once car is all up + running - job done (y)
you can take OLD battery to local recycling centre ( "tip") for free,
or you will get a few quid from a metal salvage yard.
Charlie
Charlie
Thank you very much. That is a very big help.
Many Thanks.
