Styling Roof Aerial
Styling Roof Aerial
Hi, on my Fiat Grande punto I have the standard roof aerial. I have recently thought that it looks too long so I have looked around for a new one and I have come arcoss this one - http://www.partsworld-uk.com/product/Short_Aerial_Mast-Fiat_71806072-3
I'm just wondering if anyone else has changed their roof aerial? If so would you be able to post an image of it so I could see if I prefer the shorter style.
Many Thanks
You can see it fitted to my car here :)
I think it's a great cheap mod for any Grande Punto.
Hi which one did you buy and where did you get it from as I have found the same item of the official Fiat Accesories website with the same part number but I have just spoke to them and they said it doesn't fit the grande Punto, but on parts world uk it says it's is?
Hope you will be able to help,
Thanks.
Hi All.
I have problems with replacement of the aerial, the base of the aerial. I have a sunroof and there is no back interior light, under which the screw is normally expected to be. Must I remove a whole roof covering from inside to get to the screw?
Hi All.
You don't need to remove the whole roof lining - with the boot open prise the rear headlining down very carefully and you should be able to reach in and unscrew the aerial base.
