Hi I have a 57 punto 1.4 t-jet, purchased around 8 months ago and has been in the garage 4 times with an intermittent misfire on cylinder 1. At first the fault codes indicated the coil pack had blown, so they replaced it and it ran fine for a few hundred miles before developing a misfire again. This time codes pointed towards a dodgy fuel injector so that was replaced with another new coil and a set of new sparks. After this work was completed the car was running well for around 4 months until it developed yet another misfire on cylinder no 1. They have found that the sparks are gradually becoming wet leading to a loss of spark and then a misfire, they claim that this would indicate an over fuelling issue on cylinder no 1 however are not really prepared to investigate further as they have no idea of the cause. Hopefully someone can give me some possible causes for the misfire excluding the coil pack and injector (these have already been replaced).
Cheers,
Jamie
Cheers,
Jamie
