Hi guys my first post.well we already had autobox probs with our gp 1.4 8valve 07 plate and clutch actuator was changed all good for 3/4 months then missus had no gears had a look and listen no pump heard when open door. Checked for fluid leaks/level fuses ect it turned out to be fuse /connector red one on top of battery not seen this mentioned on here may save members a lot of time and money especially if you end up with shoddy outfit mending it for you and charging you for stuff they dont do hope this helps some of you when you think pump is kaput cheers ian
