Technical Brake judder
yup.
more than likely a warped disc.
not visible to the naked eye though, so it could be any one of them
I'd suggest when you next do a pad change on the front, to swap the discs as well.
And if you are heavy on the brakes don't sit at junctions with your foot on the brakes, this is what tends to cause them to warp as the heat becomes trapped and you clamp the discs with the brakes as they cool down and contract.
