hi guys wondered if any of you had any advice. I have a 1.9 grande punto 2006. I was driving when it cut out and went into limp mode. Sat it at home over night and would not start. The sender unit in the tnk seemed to be struggling a little so i disconnected the fuel lines at the filter and the diesel came through fine so i assume no problems from the sender unit to the engine.
I called a out and they read the codes and found a high pressure pump warning so the first mistake made was to get towed to their preferred garage which is halfords DO NOT USE HALFORDS. they replace the battery and the egr valve and said it was fine. i went to collect and it broke down again in the car park. They then had it 3 weeks and could not find any faults :bang::bang::bang:
I told them i was coming to collect it and towed it home where its now sitting on the drive the problem being they wiped the codes from the ecu so its now showing no faults - wont start at all - and i have no idea
help would be great thanks
