Technical Upgrade Steering wheel with control buttons on GP Active? NEED HELP
grandearkan
slovenia
Hello,
is it possible to change the grande punto 1.2 8v active version. steering wheel (without control buttons) with a other gp steering wheel which have the control buttons?
I would not think so, because the extra buttons relate to functions such as USB and bluetooth, which I understand the active was not equipped with. These things are being controlled by the car's computer and associated wiring, which should not be present in your car. I would recommend you leave the car as it is, or upgrade to a plusher grande punto if you afford to do so.
And whats with the steering wheel with the control buttons without the windows button? I mean only the foward back src and + -
Still, I would not bother with it. THere must be cables connecting the steering wheel buttons with the stereo, it may not be straightforward to place and connect. However, you may find a garage who may be prepared to get the job done for you, if you want it that badly, just shop around!
