cmosfxx Established member Joined Apr 3, 2012 Messages 1,365 Points 263 Nov 1, 2014 #1 Hi, quick question! Can I fill oil back in gearbox from breather hole on the top?(of course the correct amount) Is it right / wrong or can't be done anyway ? GP 6 speed gearbox.
A aurick86 Established member Joined Sep 14, 2009 Messages 2,068 Points 459 Location Bucharest Nov 1, 2014 #2 why would you do that? Fill it using the correct fill hole, and 1 meter of hose.
S suzaan New member Joined Oct 23, 2014 Messages 4 Points 1 Nov 1, 2014 #3 Thats the gearbox breather. The fill up hole is on the side of the box - when you look at the side of the box you'll see 2 plugs with an 8mm square hole in them, ones the drain plug, the other is used to fill it up
OP OP cmosfxx Established member Joined Apr 3, 2012 Messages 1,365 Points 263 Nov 1, 2014 #4 Ok, ok! I know the "correct" way but is it possible ?
Avaxbox Member Parked in the garage Joined Apr 18, 2014 Messages 350 Points 62 Location Thornaby Nov 1, 2014 #5 Yeah no problem go through the breather
Avaxbox Member Parked in the garage Joined Apr 18, 2014 Messages 350 Points 62 Location Thornaby Nov 1, 2014 #6 I changed mine for red line mt85
OP OP cmosfxx Established member Joined Apr 3, 2012 Messages 1,365 Points 263 Nov 1, 2014 #7 Avaxbox said: I changed mine for red line mt85 Click to expand... Redline will be mine too. How to pull out breather cup? I can pull it up a little but it won't come off?!hmm
Avaxbox Member Parked in the garage Joined Apr 18, 2014 Messages 350 Points 62 Location Thornaby Nov 1, 2014 #8 I think I filled mine by the reverse light switch
ChrisUK Patron member Parked in the garage Written a guide Joined Apr 8, 2004 Messages 25,219 Points 3,671 Nov 2, 2014 #9 No reason why not but you need to be precise with your amount or you can end up breaking a perfectly good gearbox.
AndyRKett Distinguished member Parked in the garage Joined May 23, 2011 Messages 14,276 Points 3,365 Location Norfolk UK Nov 2, 2014 #10 I would say still take the fill plug out of the side of the box so at least you can't over fill it, when it starts pouring out you know it's full Just saves trying to fill from the front of the box
OP OP cmosfxx Established member Joined Apr 3, 2012 Messages 1,365 Points 263 Nov 2, 2014 #11 Sooo... I removed fill plug to check oil level and what a surprise! oil level was much lower than the correct spot. 1) Garage did not replaced oil when I asked them to replace it (I supplied 2 boxes of tutela) 2) 2 boxes of Tutela is not enough and fiat manual is wrong. Attachments IMG_3093.jpg 31.4 KB · Views: 35 Last edited: Nov 2, 2014
