- Jan 2, 2013
- 740
- 198
This is not the case.
Independent tests show that a clean, new paper filter will breath better than any K&N or whatever so called "sport" filter.
Only after several thousand miles, they will be equal in capacity.
Another benefit of a paper filter,besides low costs, with every change, you can clean and inspect the inside of the airbox.
So if you want the most air for your car, use paperfilters, and maybe change them a bit more often.
Remember, K&N filters are designed for big V-8 engines with large carburetors, racing in dusty desserts...
http://www.bobistheoilguy.com/air-filtration-test/
Do you have personal experience on a 1.4 GP? If so then I apologise ro your experience. However I have seen the difference on a RR dyno on engines from 1 litre minis to 3.5 Rovers. I haven't dyno'd my 1.2 GP but it does more MPG than before I sorted it as per my thoughts above and gets to 70 faster than my friend's 1.4 unless he's really as bad a driver as I've suggested!!
