Technical Help needed on poppa already :(
BenNWuk
So this is a bit of a hard one to explain I may be wrong or just paranoid.... Have a bad history with cars....
So anyway tonight my 1.9 has started making a noise i can't quite explain... It sounds like when an exhaust is blowing but it's coming from the engine to me it sounds like it's near the turbo but I have no loss in power smoke etc....
It also is making a whistling noise when the revs drop which is different from the usual turbo noise.
From what I have read it could be either a fault with the egr valve... The turbo pipe or the turbo on its way out
Any suggestions???
Any suggestions???
Sound like a bus when driving?
Not as loud as a bus though.... Done more research when I got in tonight pointing to a split pipe just got to try and find out which one
Is that the 90 degree one or the longer one after that? If I had the money I'd be getting the forge replacement pipe kit for all of them
I'm hoping it is that one found a nice alternative £15 on ebay
Bad times!!! I've searched on here and the internet since 7pm the only reason i think it could be anything else is I haven't lost that much power where other people have unless I've caught it really early
Any warning lights on or anything? Im guessing not :/
Without listening i cant really say! Back home now as well! A bit crap really seeing as you only just bought it :(
Nope no warning lights I know The plan is it to be fixed for mitcar!! gonna head to reu when he's free if I haven't already solved it getting a mechanic have a look over it tomorrow when I finish work if it's a pipe then I've still grabbed a bargain!! Fingers crossed!!
BenNWuk I have a spare EGR valve we can try if needed but I suspect its loose/spit boost hose.
thanks Reuuk ill keep you updated after its been checked im confident that ive diagnosed it correctly and its a hose thats split easy fix ebay £8.11 for a silicone one if its the 90 degree one
I'd suggesting spending the extra £6 and getting the Fluro lined one as this will protect against oil from the turbo which can break down hoses otherwise.
Well didn't have much help as he had nothing to jack the car up at his house so no luck I'm certain it's the hose split anyway Reuuk ill organise something with Carly and me and you can have a good luck??
