Technical Grande Punto Dashboard Lights
paulfgoodchild
Hi Guys, new user here. I have an 09 plate Grande Punto 1.3 multijet. I have returned to the Fiat fold after previously owned 2 different Stilo's.
The Punto is a vastly better put together car than those were.
One slight problem I have uncovered is that I have a bulb out behind the heater controls, the side nearest the driver is dark, passenger side is illuminated.
What bulb do I need and how do I take this part of the dashboard off to replace it please?
:devil:
Bulb is 286 1.2w .
You only have to remove radio and work behind the heater panel. Then you can feel the wire that holds the bulb. It's just pops out. A mirror can help you for the first time. Switch on lights to see where is the other bulb (there are two of them) and you will find the other.
Many thanks cmosfxx,
I'll give it a whirl at the weekend.
I've got some radio keys from my Stilo's Navman set up, they might work.
