When was the clutch replaced, and by whom ?
Where is the oil leak, and how bad. ?
Te replace the clutch means removal of the gearbox, which usually means disturbing the drive shaft oil seals. This I guess could be the cause of your leak.
Or quite possibly the oil your'e seeing is spillage from removing the drive shafts.
However, double clutching to get gears is not good.
Not sure if the 1.2 has a cable clutch or hydraulic, if it's a cable clutch, then usually these are self adjusting these days.
If it's hydraulic, then the slave cylinder may require a re-bleed after being allowed to expand the piston when the tension was removed.
As for the clutch it's self, it could be faulty.
It's usually rare, but i've replaced a few over the years only to find one or two had faulty pressure plates.
Removal of the gearbox, could also require some disturbance of the exhaust, which in turn may disturb the heat shield.
A buzzing heat shield gives off a very strange noise.
I guess depending on how long since the clutch was replaced, I'd be taking it back for another look.
