Hi all,
I recently bought a 56 plate punto grande from a local garage, visually the car is sound, with good low mileage. The only problem being was a big gash in the front near side alloy, although i wasnt too worried as they're cheap enough to replace.
after the test drive i decided to go ahead with the purchase. I drove it on the motorway and instantly I could tell the wheel bearing was dying, I took it back to the garage who then replaced the wheel bearing and CV joint free of charge. I noticed they swapped around the bad alloy for the nearside rear. When returning home from the garage I tested it on the motorway to make sure it was all fixed, but when getting to motorway speeds the dash lit up like a christmas tree, with the ABS light Powersteering light and handbrake light all showing, although this didnt seem to be effecting the car in anyway its just annoying and worrying because the speedo dies and the digital display also shows EBD failure. This only happens when going motorway speeds, the rear tends to wobble and then the lights come on, has anyone else had this problem? or does anyone know the fix to it?
Im sorry if its already been posted, i just cant seem to find it anywhere.
Thanks in advance
Thanks in advance
