ELA
Hi guys, having read all the threads possible here regarding this matter it would seem there are a few options. I would really appreciate some guidance in the following areas:
1. Air filter: GSR or Forge induction system? (a little worried about heat soak with the Forge as it is an alloy pipe). Also, where does a fitted filter get airflow; do you guys normally remove the foglight?
2. Exhaust: is this one any good (if not please suggest a better alternative?)My requirements are performance is top priority, don't want anything too lary, so fairly stock looking but with a nice sound) http://www.italo-tuning.de/friedrich-exhaust-system-635mm-catback-7-p-8141.html
3. Re-map/chip, what is the recommended option?
4. One thing I don't like with this car is the sloppy gear shift, is there a a short shift kit available?
I am only looking to take this car to about 160bhp so items 1-3 listed above should be based on this power figure, i.e parts suggested should be optimised to suit this power level.
