Technical Annoying creaks
Paterson1
Member
When im driving im hearing creaks I think from my suspention any one know where this could lie? All springs are fine
Jake
Rang fiat and they said theres a recall on it for lower steering shaft tightening?
Ring them tell them your reg ask about recalls amd they will tell you what outstanding you have I did look it up on vosa aswell and it says if the steering nut is too tight there can be emmisions of noise so im booked in for thursday and se if that does the trick :)
Guessing this will be fixed by them for free.
Is there a way of knowing if anyone else can go in for recall work or find a list of what your call should have had done to it with regards to recall work?
I used to have a similar noise but this it was the door catches, insulation tape around the catches seems to have solved that though lol
Hmm, I seem to get the same thing, rear of car creaks a little when I throttle hard and let go, may give them a ring.
It's an 06 GP, will they fix it regardless of age as long as it's been recalled/due for recall?
Assuming free of charge?
Had them done 100miles ago :( im startong to think ball joint as I can only hear it by the left wheel
Have you checked the anti roll bar links and anti roll bar bushes? What about engine/gearbox mounts? You should be able to check ball joint by jacking car up and shaking the wheel at 3 and 9.
Sent from my iPad using FIAT Forum
Engine mounts wouldnt make it do it as its steering right? And I dont know wjere im checking for the ball joint?
