DrumRollChris
- Nov 18, 2013
- 194
- 41
Went out a long drive enjoying this fantastic weather... driving home and the car started to feel as though it started to lag a little while in gear (constant smooth acceleration and then without lifting my foot off the accelerator it felt as though I was coasting for a second or two) anyway, that went away and I turned into my street where I was in 3rd gear straight after the turn (as normal) and then it pulled back hard while in 3rd.
Never panicked and put it into 2nd to get more power... same thing happened, and again in 1st! Only way it moved forward without and resistance was coasting and then it came to an abrupt stop.
Killed it and then turned it over and it idled at around 300rpm (didn't sound good either) had to push it down to my house with the help of a neighbour.
Got it back safely and turned it over once again and it starts and runs fine now.... scared to drive it anywhere further than out my street without having to leave it overnight.
EML is on which I can't read the code for at home... Please can someone give me any advice in diagnostics or symptoms of a problem?
Want to take it to the garage but I've got no notion of only managing half of the journey...
