General GP Code Reader
BloB3rt
Hello,
Can anyone recommend a cheap fault code reader that works with the GP please?
I bought one that was meant to work with a large list of manufacturers only to find another seller with the same product gave a very different list that did not include Fiat.
The reader did work on my friends ford so it was just misleading information :(.
this worked fairly well for me
V1.5 ELM327 OBD2 OBDII Bluetooth Vehicle Car Diagnostic Interface Scanner
as it came it can read the engine/abs/steering
to make it read the airbag/body/blue&me/instruments you need to open it and remove a resistor, (see pic) and move the wires from pin 6 to pin 1 and 14 to 9 on the back of the connector. you also need a registered version of multiecuscan to reset some of the codes.
Mes is the best you can get. On the website you can see what cables/adapters they recommend.
Sweet cheers,
do you know what cables/leads I would need for my car?
2006 GP 1.9 Mjet.
look on the Supported vehicles list..,;)
for Engine stuff.. you'll need either;
a VAG COM - KKL lead,
or an ELM327 interface. = check which is needed for your car..!!,
then the coloured leads link with the other lead
to get ABS, PAS and AirBag coverage,
you can buy the ELM + KKL separately pretty cheaply, ( £5 to £15 )
or get everything in a "5 lead Bundle" for convenience..,( £25 to £50)
Charlie
Sweet cheers,
2006 GP 1.9 Mjet.
looks like you will be using the ELM cable.. for all GP stuff (y)
(NOT the KKL ..!!)
BUT may need the coloured "adaptor leads" for a lot of the different features..,
read the list on MES, and you'll see what I mean.., ;)
if you want more in-depth help , the TECH section on here ( FF) has a few poeple who've pointed me in the right direction..,:worship:
Charlie
I don't appear to be able to read the engine module without a license/subscription.
I thought reading the codes for the engine module was free on the free version?
Rob
Rob
Should work..:confused:
use the F9 - bottom left - to test connection,
( you MAY have to adjust the port speeds);)
then once all set-up you can connect to the necessary module,
BARE cable for engine..
need coloured leads for ABS, PAS + airbag,
Charlie
Thanks i will try changing the port speeds today, is there a recommended setting?
Yep, I have the standard ELM327 cable and it finds all the modules in the car but when i 'Connect' it flashes up the results but gives me a popup saying this is restricted and then goes back to the 'Homepage'
So maybe it isn't a settings issue :\
I will try reinstall it aswell.
