Dear All,
Nowadays I experience strange issue with the 75hp 1.3 Multijet.
As the engine starts, sometimes just after the start the "check engine" light comes up. 2 weeks ago a friend of mine read the code with the Fiatecuscan and found P0340: Camshaft position sensor circuit.......
Strange, that the error is possible to be erased and totally randomly it could come up, but only right after the start of the engine, but not always. Never comes up during ride or once the engine is running for more than 10 seconds or so.
The engine runs perfectly as any time before. Accelerates well, consumption is the same, runs smooth, no jerking or etc.....
Sometimes upon twisting the ignition key I do not hear the fuel pump buzzing immediately, just 2~3 seconds later, but it does not influence whether the car will start-up immediately as I experienced.
Sometimes the engine does not want to start. After ~3 seconds of starting, the engine suddenly starts in those cases, but in that case the "check engine" light surely comes up.
Very strange symptoms and my mechanic is fully booked nowadays to deal with the car.
Do You have any idea or experience about such an issue?
Laszlo
Laszlo
