Hi all,
Any clues to my problem ?
i have a grande 1.4 8v 2006, My engine light has came on and vehicle has gone into limp mode and the rev counter display has stopped working (just stays at zero revs) !!! I have put a code reader on it and getting 2 codes
P0335 & P0335pd (looks like a little pd at end) I know this is pointing to the crankshaft sensor but on 2 occasions when reseting module it has been fine for ten mins, rev counter working, no engine light, no limp mode ! then just stalls and when restart ! its back in limp mode !
Can a crankshaft sensor work one min then not work the nxt ?
Any info on these symptoms would be grately apreciated !!!!
Thank you
Thank you
