If the plug is misfiring it will look different. The deposits are unburnt/improperly burnt fuel. This does not mean the plug is at fault.
Swap them between cylinders and try again. Clean or dirty. If the misfire moves, take the plug back and demand a replacement. If the misfire stays on cyl 2, look at leads or coils. Swap components to see if misfire moves.
Move leads around first. This tests the leads.
If no change, swap the coils around. When the misfire follows the component, you've identified it.
