Technical How to access fuses behind glovebox?!
robpunto1
I believe the fuse has gone for all my interior lights (even the boot one doesn't work).
From looking across the forum I believe the fuse for the lights is located in the fusebox behind the glovebox..
Can anybody tell me how to gain access to these fuses?!
Many thanks!
Rob
Thanks for that! My GP is a sporting model, so has the blue&me system with its USB imputs getting in the way in the glove box. Where I assume the black plastic cover should be is an array of bolted on metal bits that support USB sockets!
Any ideas!
Many thanks again! :)
(I can barley see the fuses, never mind checking them or pulling them out!)
Ah okay, so did you just use long thin pliers and work your way around all the blue&me apparatus? :)
You can access two banks of fuses that way. But there also seem to be relays on that board, and you can't get at them because there are metal flanges over the top of them.
The flanges are held in place with pop rivets and a tamper-proof bolt. They are not intended to be accessed. So, as far as I can see, if one of those relays fails you need to junk the car...??!!
