janco123
- Mar 30, 2013
- 44
- 12
Hi all. First of all I would like to apologise for my not very brilliant English.
So lets start with the problem. When I was driving my fiat grande punto the warning light for the oil started blinking. After a while it turned up with a beep saying " Insufficient Engine Oil Pressure Warning - turn off " or something like this. I immediately turned the car off, waited for about half a minute and then turned it up again. There was no warning. So I drove for about 100 meters and the warning started flashing again, and then the beep. I stopped the car on the parking place and checked the oil level. It was very low so I refilled it. I assumed every thing will be fine now so I stared the car, no message appeared. Then after 2-3 minutes the oil light started blinking again and than the beep with warning message. I stopped the car, turned it off and than on again and there was again no oil light showing up- after a while it beeped again. The engine isn't making any strange sounds. Just the oil light is turning on when the car is turned on for 2-3 minutes. Where is the problem?
Hope you understood my English ;p
