Thread Tools
Old 21-10-2012   #1
Removing an Alternator
Hi , I am trying to remove and replace an alternator on my 2007 1.4 , having difficulty removing the alternator,it has air con. do i have to remove the air con first or not? ant replies would be grateful thanks
liz1961 is offline Reply With Quote Quote
Old 25-10-2012   #2
Re: Removing an Alternator
Hi just take bolts out on the air con then you can move it out of the way & get to the top bolt on alternator hope this helps .
N3ERN is offline Reply With Quote Quote
Old 25-10-2012   #3
Obviously i don't know the facilities you have access to..If you have access to a ramp you can remove the alternator from beneath,Or put the car on axle stands .When i did mine i had the luxury of a ramp and an aircon machine so i could unbolt the aircon compressor..I'm not sure how much movement you get just unbolting the compressor with the pipes still connected.Some people would just empty aircon in to the atmosphere ,but be aware gas is dodgy and it is illegal to empty it in to the atmosphere
phil0254 is offline Reply With Quote Quote
Thread Tools
(T) Removing a sporting 1.1 MPi alternator Jonfiat Cinquecento / Seicento 6 30-05-2012 21:53
(T) need halp removing alternator andycam06 Punto (Mk2/2b) 4 19-02-2011 00:12
(T) Is it my Alternator? satis Cinquecento / Seicento 8 04-11-2009 19:20
(G) removing alternator- help needed orangewheeledwonder Cinquecento / Seicento 3 09-06-2008 01:42
(T) alternator wlt Cinquecento / Seicento 1 10-06-2004 01:48
