Thread Tools
Old 25-08-2012   #1
willeywilson has donated!
M32 Gearbox Bearing
Now I know there are lots of threads on this topic but I couldn't find what I was looking for.
I know my lower shaft main bearing has decided it has had enough and been whining for a while now, as well as a very sloppy gear stick. As annoying as this was I was ignoring it for a while, but now I have to do a 180 mile round trip to work every day it has become something of an urgency to fix.
Now from all of the Vauxhall threads I have read I have gone ahead and ordered and received the bearing. Looking at the bearing in the packet is has a film of oil covering it, essentially my question is, is it worthwhile pre-greasing the bearing like you would with a wheel bearing? Or should I just pre-oil it with gearbox oil and put it all together?
Also, has anyone had any experience of doing this? I have read it is possible to do this whilst the gear bag is in situ on the Astra without removing the subframe and dropping the 'box. However, the Punto has a lot tighter engine bay, is it possible to remove the gearbox end cap and replace the bearing with it in place, or am I going have to drop everything off the car?
Thanks in advance
Adam
JTDM - Jess The Diesel Muncher
Click For Members Motor
willeywilson is offline Reply With Quote Quote
Old 27-08-2012   #2
JimbbobW1977 has donated!
Re: M32 Gearbox Bearing
I know that when mine was done I went and saw it at the garage sitting outside waiting for a part. The gearbox was removed and the right side of the engine held up with rope.
The delay on getting mine fixed was that it needed a specialist tool for the baarings to get them back in, the garage had to borrow this tool from a gearbox specialist in Derby.
JimbbobW1977 is offline Reply With Quote Quote
Old 27-08-2012   #3
puntopower!
matty seasider's Avatar
Trader Rating: 6
matty seasider has donated!
I think you may find the one bearing won't cure.
Mine needed bearings on 5th and 6th, main shaft, and both diff bearings.
Fiat main dealer didn't even have special tools, they just swappedy box , first time for recon, 2nd time for a new one as recon lasted less than 6months
PUNTO GRANDE SPORTING MJET :
RED-DOT REMAP RUNNING 194.8Bhp 328.8 ft-lb torque
matty seasider is offline Reply With Quote Quote
Old 28-08-2012   #4
I can confirm replacing the lower main shaft bearing has cured the whine and upon inspection is the only bearing with severe wear as described from all the Vauxhall threads. The gearbox is now very quite but 3rd and 4th still vibrate slightly when your hand is on the gearstick, which is fine for now until I can be bothered to do the other bearings. The gearbox no longer throws the gearstick backwards when you lift the clutch up in first gear and the slack has been taken out of the throw of the gearstick. Bit of a 'mare of a job but you only have to take the battery and battery tray out, gearbox mount off and then release all the nuts securing the gearbox end cap to the bell housing. Dropping the engine slightly makes access a lot easier.
Remove the circlip from the bearing and using a puller, pull 6th gear out a good 10 mill which in turn forces the bearing towards the end of the shaft. Then slide the 6th gear back to its original position and use the puller on the bearing itself. (This did require a bit of heat to get it to come off)
Push the new bearing on with the puller (used in reverse) refit the circlip. refit and fill with gearbox oil.
Job Done.
Just make sure 6th is on its synchro properly.
47 repair v 1000 recon box
Likes IsThisGoodbyeMrT liked this post
Old 28-08-2012   #5
WilleyWilson lives up to his name. Impressive effort.
Thanks willeywilson thanked for this post
Likes willeywilson liked this post
jameshobiecat is offline Reply With Quote Quote
Old 28-08-2012   #6
I'll do a proper walk through when I have time to write it out properly and upload a few photos. Thanks mate
Old 29-08-2012   #7
Moderator
ChrisUK's Avatar
Trader Rating: 1
ChrisUK has donated!
Bartender Champion, Wood Firing Champion
Awesome. I thought mine was a gonner too. But I have no symptoms EXCEPT a whurring noise in 1st, 2nd, 3rd and a little bit in 4th. It's not a whine.
I'm confused and so is the Evans Halshaw that sold me it lol.
ChrisUK is offline Reply With Quote Quote
Old 29-08-2012   #8
If it is in the first four gears I would suspect the diff bearings or input shaft bearing. The most common to go is the lower shaft main bearing, like mine. It is the smallest main bearing in the 'box and carries 1st 2nd and 6th, (possibly 5th too but I can't remember off the top of my head) and hence gets a lot of use. Stupid design :/ some Vauxhall boys have even gone to the length of putting a gearbox cooler next to the intercooler :/
Old 29-08-2012   #9
1.9 Mjet Caribbean Orange
S1M0's Avatar
S1M0 has donated!
Picture Find 2: Landscapes Champion
Quote Originally Posted by ChrisUK View Post
I have the exact same symptoms, took it back to fiat and they couldn't tell me what it was!
S1M0 is offline Reply With Quote Quote
Old 30-08-2012   #10
Moderator
ChrisUK's Avatar
Trader Rating: 1
I took it to a private independent fiat specialist and he said he's 90% sure it was diff bearings, due to it being a wurring rather than a whine.
I guess I'll just book it in again and try and be persistent to get a fix with the 8months left I have of my warranty . Hopefully a recon box I don't see them doing the work themselves unless they have a Evans Halshaw vauxhall near by lol.
And would a gearbox oil cooler really help with the longevity of the gearbox?
Old 30-08-2012   #11
Due to the very small bearing used on the most used shaft in the box, in theory it would help reduce built up heat and protect the bearing. Although the old bearing is always pitted and very worn which I would suggest is due to the design of the box not the heat induced. Vauxhall boxes are always notchy and this is no exception. I added some molyslip and it feels a lot smoother. Although i was being very gentle with the gear stick
Old 31-08-2012   #12
Moderator
ChrisUK's Avatar
Trader Rating: 1
That's weird then. The gear shift in mine is perfect, 100% smooth, no notchyness, no grinding, no jumping out of gear and very precise.
My only criticism is the length of the throw.
Old 31-08-2012   #13
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Hope you paid the deposit for the car on your Credit card
Massive gash
Just a little touch up
Old 31-08-2012   #14
Moderator
ChrisUK's Avatar
Trader Rating: 1
lol nah but I've got finance on a portion of it . It's under warranty .
Old 03-09-2012   #15
Just a thought for those of us who are fortunate enough not to have any symptoms or drive with the radio too loud, would it be worth adding some of this monoslip stuff
if so how is it done and could it cause damage
barnyard.c is offline Reply With Quote Quote
Thread Tools
(T) 1.9 Multijet Gearbox (M32) reliability. Hellcat Croma 15 26-07-2012 10:52
(T) The worst designed gearbox ever M32 rubbish little red pocket rocket Grande Punto 3 20-03-2012 11:30
(G) m32 gearbox benpunto Grande Punto 0 09-06-2010 16:53
(T) Punto gearbox bearing? bluepunto2 Punto (Mk2/2b) 0 20-02-2009 23:25
