Right I have a bit of a problem at the moment & that is the O/S/F Alloy has welded itself to the Hub.
I have tryed a couple of different tricks to remove the Alloy, one being using a small block of wood & a hammer, that didn't work.
I have also tyred lowering the jack so the weight of the car presses down onto the wheel, no luck there.
I haven spoken to Bridgend & all they could suggest was apply heat to the Wheel Hub. :bang:
I can't get a bar behind the Alloy either due to the Alloys not being standard Fiat alloys, so if one got broken/ damaged I'd be looking at ££££££ to get it replaced
Obivously I don't want to damage the Alloy wheel, anyone got a sencible suggestion??
