Technical " radio blocked, wait " message on Grande Punto
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🎵
blueta
Hello every body, i have a Grande Punto blaukpunkt CD Mp3 system with bloutooth, with a battery change, and as i lost my code, i tried several codes, all wrong, until that i have the " radio blocked, wait " message, since two months, please how to reset the system / radio ? thank you for your help.
The radio manual states the waiting times between entering the wrong codes. Eventually the radio will be locked out, and can only be reset by a specialist.
The radios are matched to the vehicle's Body Computer, so if the battery is disconnected you will not need to enter the code as it is automatically recognised. If you're having to enter the code, it means one of these is not the original unit and you'll have no way of getting the correct codes as they won't match Fiat's/ISR's records.
Your only option is to get it sent to a specialist and unlocked.
hey just wondering did you fix your problem with radio, im having the same problem if you could kindly help ?
Does the radio not have a set of identifying numbers on that will allow you to get the code of Fiat or a specialist?..
Another option is to get another. from a breakers.I bought a fully working cd player unit ,with code for £10 yesterday.
Took longer to get the original out than it did to put the code in and set it up!
