Technical power steering failure/air bag failure, no radio or clocks
Davies5390
ok so i go to jump into my new grande punto yesterday and started her up but i had had no power steering at all lights were up on the dash telling me to check hand book etc
turned it of phoned my warrenty company need to book it in on monday
went back out it was working then i had airbag failure
another time then i started it had power steering but again airbag failur and no radio indicators or my clocks wouldnt work at all no oil temp no revs no speedo
its now all working again
my question is what could this be?
and if i book it in will they still find the fault? even though it seems to be back to normal? i had it from a mazda dealer who put a years comprehensive warrenty on it for me so i know im covered for electrics just curious if they will find the problem ?
I get the same problem but even though the dash doesn't work everything still does. For example if you indicate it doesn't flash on the dash but externally they are actually working. Mine has done it a few times there's no pattern to when it faults so a garage will never fault it.
