Thread Tools
Old 14-11-2011   #1
Gear stick moves when accelerating - 1.9 Sporting
Hey,
Just got a new Punto this weekend and would like a bit of help please
http://www.fiatforum.com/newbie-cent...ml#post2896947
I didnt notice on the test drive, probably because I couldn't get it up to speed, but when accelerating, the gear stick moves forward a bit, and then backward when foot is taken off the pedal.
It's most noticeable in 5th and the movement is about 1-2cm.
Is it anything to be concerned about? I know its a big Diesel block in the car, does it happen to anyone else? Some people say its nothing unusual just the engine moving on its rubber mounts, others say the mounts are too loose and it needs sorting.
Its a 1.9 Sporting, 35000 miles.
Cheers!
Dittoo is offline Reply With Quote Quote
Old 14-11-2011   #2
puntopower!
matty seasider's Avatar
Trader Rating: 6
matty seasider has donated!
Re: Gear stick moves when accelerating - 1.9 Sporting
Quote Originally Posted by Dittoo View Post
Hey,
Cheers!
mine was doing that, got to the point where it moved a good 1-2inch so took it to dealer and diagnosed as needing new gearbox, it had a new mount prior to that which did nothing. they said it was excessive play inside the box. tight as a tiger now with a new gearbox
PUNTO GRANDE SPORTING MJET :
RED-DOT REMAP RUNNING 194.8Bhp 328.8 ft-lb torque
matty seasider is offline Reply With Quote Quote
Old 14-11-2011   #3
New gearbox?
How much was that Was it covered under warranty?
Old 15-11-2011   #4
puntopower!
Trader Rating: 6
Yeah covered under extended warranty, dealer said the boxes are 1700 ish
Old 17-11-2011   #5
just an update to this. My car did this but since i got it back from the fiat garage and it had it radiator replaced it doesnt do it anymore... Strange I know but im not complaining.
monsi88 is offline Reply With Quote Quote
Old 19-11-2011   #6
Well ive called a couple of dealers and they both have said it's nothing to worry about, just the engine moving on it's mounts.
If it gets any worse i'll take it in but it seems all good
Thread Tools
(T) Gear stick moving in 3rd gear ?? bravotony Grande Punto 1 11-07-2011 13:23
(T) Removing (standard) chrome gear stick nob: Sporting Speedgear Automatic 02 reg plate) revtastic Punto (Mk2/2b) 8 08-04-2011 21:52
(G) gear stick play / steering wheel cover / gear knob Jamie1978 Scudo 0 06-12-2010 18:49
