Old 22-02-2011   #1
Check Glow Plugs Warning (plugs have been replaced)
Hi
Can anyone help please? I've got a punto 1.3multijet and have a bit of a problem
The check glow plugs warning came on so i had the plugs replaced but the warning is still on!
Since the plugs have been replaced it takes the car two attempts to start from cold, after its been used a couple of times in the day it starts first time. (before they were done it started and drove fine just had the warning message)
Took the car to Fiat yesterday and was charged £90-odd pounds for them to say theres nothing wrong but come back and have a full wiring check at a cost of £145 and that might find a problem (The message is still on)
Is there anything else i could check before resorting to spending loads of cash on it?
theboothenend is offline Reply With Quote Quote
Old 22-02-2011   #2
1.4 8v Active Sport
Magic Johnson's Avatar
Magic Johnson has donated!
Re: Check Glow Plugs Warning (plugs have been replaced)
Could be the relay.
Magic Johnson is online now Reply With Quote Quote
Old 22-02-2011   #3
bladecs_04 has donated!
on start up do u let all the lights on the dash go off before you fully start it.
did it work correctly before you had the glow plugs changed e.g. started first time. if so i would take it back to the garage you had them done and get them to sort it.
try disconnecting the battery for 10 mins to reset the system.
small guide for switched ignition: http://tinyurl.com/3bm5huy
my members motor thread: http://tinyurl.com/3pe3qc6
Details for heater lightshttp://tinyurl.com/bqjwd4d
bladecs_04 is offline Reply With Quote Quote
Old 22-02-2011   #4
1.4 8v Active Sport
Disconnecting the battery will not clear faults from the ECU.
(T) Check Glow Plugs prepress Bravo 1 11-05-2010 20:07
(T) Blown Glow Plug Fuse (Check Glow Plugs Msg) monkeydt2003 Grande Punto 22 04-04-2010 11:21
(T) warning "check glow plugs" 1.8Stilo Grande Punto 11 20-09-2009 19:28
(T) 'CHECK GLOW PLUGS' Warning 1.3 multi baxwalker 500 6 25-09-2008 20:02
(T) Brava 1.9td glow plug light flashing after plugs replaced Gort Bravo / Brava 12 27-05-2008 09:11
