Technical Engine check light w error code
ks66
any bro know what is error code mean, I use an OBDII software to scan the car found this error.
PO657-- Actuator supply Voltage A Circuit/Open
Thks
EOBD code Fault location Probable cause
P0657 Actuator supply voltage - open circuit Wiring
you need to check the wiring to the actuator from the ecu
mine is a n.a,i dont understand wat it mean " wiring to the actuator from the ecu "?
