Okay guy's what do you make of this, My 1.2 active on a 57 plate won't start just completed dead all the electrics come on the battery is fully charge but nothing when you turn the key anyway had to get somewere today and had no option but to push start it, any way my power steering light was on but steering worked fine, then the light went out and then on the way back after push starting it again how embarrasing that is lol, the power steering light was on again but i also notice my speedo stoped working as well then again after 5 minutes or so the power steering light went out and the speedo started working again. I have check the to main earthing points from the battery one on the frame and the other on the gearbox and both apear okay, am i right this must be an electrical fault.
thanks in advance guy's
Have you given the main earth on gearbox a good tug they have glued on heat shrink wire can rot looks ok till ya pull it out of heat shrink then its all green.
Have you tried a good jump lead from battery to earth or use a meter from battery to engine and check earth circuit
