I would just like to bring to the attention of all Grande Punto owners a problem/fault that I am experiencing and expect many of you are or will be after reading this post...
I am an owner of an 06 GP and recently noticed that the carpet in the rear driver's side foot well was wet, so decided to pull back the carpet only to find a considerable amount of water in both the front and rear driver's side foot well’s. The soundproofing is also able to be removed completely which had acted as a sponge! Having rung out a large quantity of water it took a further 2 days to dry out completely on the washing line!
I then took the car to a local private garage to test for water ingress, but was unable to locate the leak. It was at that point that I searched the internet only to find some other Grande Punto owners with the exact same problem, one of which was on a 4 month old car!
The cause appears to be a corroded plate which the brake servo is bolted to on the bulkhead. This then leaves a nice hole for the water to find its way through, into the inside of the car and runs down underneath the carpet.
I went back to the local private garage and showed them the plate and they were shocked to see that on a 4 year old car and suggested I go back to Fiat as it should be covered by the 8 year anti-perforation warranty.
So today I paid a visit to the "helpful" Fiat dealer and showed them the problem. They told me that it was not covered by the anti-perforation warranty as it is not classed as "bodywork!" and then was told that I would have to call Fiat customer service (if there is such a thing!) and see what they have to say about it.
As this seems to be happening to quite a few (across the whole age range of GP's), surely this is a design fault or a manufacturing defect...? I feel this may be a case for Watchdog and Trading Standards.
I urge you to check your Grande Punto for this problem and please reply to this post if you do discover this has happened to you.
Thanks for reading and please show your support.
I will keep you updated on any developments.
James
James
