screamer pipes are pretty cool, though you have to be careful with screamer pipes, you connect it to the wastegate and you are meant to reconnect it to the exhaust system before the cat. thats the legal way. however you can ( which is illegal and im guessing the more popular and common option) leave off the screamer pipe and not reconnect it this means its kind of acting as another exhaust and vents out gases into the atmosphere, this creates the loud noise you hear. its illegal apparantly, and from what iv heard about them, very annoying after a while as its like travelling with a harrier engine in your bonnet
however, its not been done before, and could be cool
You will need a new aftermarket exhaust manifold as well...Quite expensive job for nothing tbh...
If you do it, drop a video in a post, want to hear what it sounds like
I promise if I do I will upload a youtube vid and show you all, but was really just contemplating it at the moment, not sure what the effect would be on a small(ish) turbine.
Incase anybody's wondering, it's what the Ferrari F40 has that makes it go..
WWAA - vaaaaaaarrrrrrrRRRRRRRRRRRIIIIIIII
.. sorry lads I get somewhat excited talking about screamer pipes
Why would I need a different manifold mate?
From what I understand as a "screamer pipe"....U mean that u want to run on an external wastegate, it that right??
Haven't done much research but yes I was going to do that, don't T-Jets have external wastegates
I like your enthusiasm
Well as far as I'm aware, I'd be able to change the sound how I see fit, (louder, quieter) by altering the pipe bore, but I'd have to disagree with it getting annoying after a while as it would only come open in full boost
As far as I know it wouldn't affect an MOT as the emissions aren't tested at WOT so should be gravy - and as long as you promised never to go overboosting your little GP.. not an ounce would set foot in the atmosphere.. that is until you went and used it 'off-road' in which case it'd be perfectly legal.
Would sound quite nicer then a fart can on the back end, I'm sure you'll agree Gentlemen.
im not sure though if it affects performance in any way, if itsacting as an exhaust kind of, wouldnt it mean more pressure can ecape at once, meaning more of a boost?
Indeed an external wastegate allows more control and precise adjustment of the turbo pressure..
Sick innit tischhhhhhhh
Never heard a screamer pipe have you?
YouTube- BEST SKYLINE SOUND
Bearing in mind I got bored of my atmospheric dump-valve after a week, I think this would soon get on my nerves too.
Didn't understand my post did you.
