Old 31-01-2010   #1
Blown Glow Plug Fuse (Check Glow Plugs Msg)
Hi all,
Just need some advice if possible please?
While putting the swirl gasket on my EGR I caught the spanner on the Glow Plug Control Unit (a few sparks) and then nothing.
Immediately, turned on the engine, initial start up check ok, then the dreaded 'Check Glow Plugs' message came up. Had a look at the Glow Plug fuse in the battery fuse box and it was blown...no surprise.
Couple of questions:
1) I am right in my assumption (if it starts) that it's fine to drive as the GPs are only used at start up?
2) Is the Glow Plug fuse easy to fit and are they readily available from Fiat dealers?
I may have shorted the controller and/or glow plugs but the fuse is the best place to start.
Thanks for any advice.
monkeydt2003 is offline Reply With Quote Quote
Old 31-01-2010   #2
95bhp 500 Sport
alexh365's Avatar
Trader Rating: 1
alexh365 has donated!
Re: Blown Glow Plug Fuse (Check Glow Plugs Msg)
Quote Originally Posted by monkeydt2003 View Post
Hi all,
Please say you spotted the bit in the guide about DISCONNECT BATTERY!
Edit - My bad it doesnt say that, but surely you'd do that just because you were disconnecting an electronic component.
alexh365 is offline Reply With Quote Quote
Old 31-01-2010   #3
I'd finished, put the batt back on, and noticed I'd left a spanner in there...took it out and spark.
Unlucky? Clumsy? You decide.
Old 31-01-2010   #4
To be fair...
...the mistake is made.
Any help on my enquiry at all?
Old 31-01-2010   #5
Hi guys, anyone help on these q's??
Old 31-01-2010   #6
puntopower!
matty seasider's Avatar
Trader Rating: 6
matty seasider has donated!
I had that message check glowplugs, took it to dealer and they replaced all glow plugs under warranty.
PUNTO GRANDE SPORTING MJET :
RED-DOT REMAP RUNNING 194.8Bhp 328.8 ft-lb torque
matty seasider is offline Reply With Quote Quote
Old 31-01-2010   #7
95bhp 500 Sport
alexh365's Avatar
Trader Rating: 1
Quote Originally Posted by matty_oakley View Post
Yeah accidents happen bet u'll reember next time tho.
If you accidentaly forget to say what you did this is an option, but at worst the plugs are 20-25£ each.
Is the fuse not just a normal mini blade one?
Old 31-01-2010   #8
Forum Moderator
T14086's Avatar
T14086 has donated!
ZZAAAPPPPPPP
ok to drive,just will be crap at starting when cold. From memory its one of the main fuses in engine bay fusebox.....got a test light/multimeter?
Old 03-04-2010   #9
Dub Dub Dub
Aircooledbug's Avatar
Aircooledbug has donated!
I've done the same thing as Monkeydt2003, but what I would like to know is which fuse is it? Don't say look in your manual because I have lost it... well no I haven't I have just miss placed it If anybody can help me that would be great, another question... how the hell do you change the glow plugs on the GPS, as the caps have connections so it ain't as easy just to whack a socket piece on there.. thanks in advance!
2006 Caribbean Orange 1.9 Multijet 130
Aircooledbug is offline Reply With Quote Quote
Old 03-04-2010   #10
Moderator
Andy Monty's Avatar
Andy Monty has donated!
well the e-learn manual now only appears to show the s2 fuse box (perhapse they had enough on the S1's letting water in and redesigned it )
you can get a dedicated Glowplug socket with an open side so you can thread the wire through the side...
its simple to check a entire fuse box in a matter of minutes
get one of these 12v testers cost about £3
then clip the croc clip to earth or the negative post of the battery
you can use a multimeter but why over complicate something
now with the screw driver end
touch the probe to each side of the fuse if you look closely there is 2 cut outs on top of the fuse one on top of each "leg" to get a probe on
do each side of the fuse your blown one will only light the screwdriver on one side (its far faster than looking through the manual
Massive gash
Just a little touch up
Old 03-04-2010   #11
Dub Dub Dub
I actually took all the blade fuses out and checked them all, all were ok, the big 40 amp buggers I never checked... its either one of these or the square look thingy's or are they totally different things all together?
Old 03-04-2010   #12
Moderator
Andy Monty's Avatar
Quote Originally Posted by Aircooledbug View Post
with my method no need to take fuses out
the square things are relays
it probably is the big 40amp jobbies or the large flat ones on top of the battery post under the little cap will dig my handbook out later if i get chance
added a warning to the top of your guide Aircooledbug
Massive gash
Old 03-04-2010   #13
Dub Dub Dub
Quote Originally Posted by Andy Monty View Post
Huh?
Old 03-04-2010   #14
Moderator
Andy Monty's Avatar
Huh?
Don't tell me you forgot you wrote it
http://www.fiatforum.com/grande-punt...egr-valve.html
Should see Alex365 at FF meets he must make a killing doing EGR services in pub car parks with his fetching latex gloves
Massive gash
Old 03-04-2010   #15
Dub Dub Dub
Awesome touch Andy, yeah, I think I have become a bit of a pro at the old EGR valve removal. Changed mine in 30 minutes... glad to have my car back with its 130 supposed horse power, felt like only 60 before the renewed valve...
(T) warning "check glow plugs" 1.8Stilo Grande Punto 11 20-09-2009 19:28
(T) 'CHECK GLOW PLUGS' Warning 1.3 multi baxwalker 500 6 25-09-2008 20:02
(T) Brava 1.9td glow plug light flashing after plugs replaced Gort Bravo / Brava 12 27-05-2008 09:11
(G) glow plug fuse blowing hughes_fr Bravo / Brava 9 19-02-2008 00:22
(T) Fiat Tipo 1.9TD Fuse for Glow Plugs & Fuel Pump darkwolf2000 Tipo 0 11-04-2006 19:57
