I don't remember having this problem to such an extent with my last GP (active, no aircon). It's become particulary acute this week with he colder, wetter weather.
Sometimes it is so bad it has been running down the windscreen and I've had to wipe it down with a microfibre cloth rather than just a quick wipe with the demisting pad. The problem seems to happen all round the car but is mostly at the windscreen.
Running the climate control with the AC on helps but I don't think I should have to have it running all the time - especially when its just cold outside not wet. The other morning when I went to work the inside of the windscreen was more frozen over than the outside!
The issue isn't helped by the fact that the vents below the windscreen miss the bottom and blow onto the glass about 1/3 way up.
I've looked around for any sign of a leak but the carpets and headlining appear to be dry and there isn't any musty smell usually associated with a leak.
Does this sound familiar and juts a GP trate or does it sound like there is a fault somewhere?
