2 ways.the expensive one and the cheap one. the expensive one is to buy the arm from fiat.the cheap one is to buy from another store a rubber for wipers,cut to the size you want and replace it.but is a little tricky.that is what i did to mine. i removed the plastic covers which are to the edges of the rubber slided it out and installed the new one. but i removed the arm by pressing the two ''butttons'',i don't know the exact words in english,but the ones that have kind of carved lines on.if you pull out the arm then just remove the rubber as deiscribed above.hope this helps!
