| Brake Pad Wear Indicator on GPS Does the GPS have a brake pad wear indicator? I have the OEM pads still on and have covered approx 25,000 and still not come on. Maybe it's just me but my Clio needed new pads and discs @ 18,000 and my old Beemer every 12,000. Are the OEM pads that good for longevity?
__________________ 1.9 Sporting Exotica Red, 180BHP,Sub Woofer, Phillips X-Treme +80% Headlights, Phillips BlueVision Sidelights, Silvervision Indicator Bulbs, Roof Rack and Headlamp Protectors | |||
| Forum Moderator | Re: Brake Pad Wear Indicator on GPS you should be able to easily see how much 'pad thickness' is left if you look at the callipers.
| | #3 | ||
| Re: Brake Pad Wear Indicator on GPS Had a look but couldn't really see, brakes still biting well. Do you know if the 1.9 GPS has the indicators T??
| | #4 | ||
| Forum Moderator | Re: Brake Pad Wear Indicator on GPS use a good torch to check pads & yes has a indicator on n/s/f pad.
| Is this wire for the brake pad wear sensor? | brickdog | Grande Punto > Technical | 10 | 13-05-2008 16:30 |
| Brake Pad Wear 1.3 Multijet Sporting | wardth | Panda (New) | 38 | 07-01-2008 17:39 |
| Disc and Brake Pad Wear?? | Ophio | Panda (New) | 11 | 14-10-2007 09:35 |
| Brake Pad Wear. | Trancendental | Leisure Lounge | 17 | 16-07-2007 11:52 |
| Pad Wear Indicator | Argonought | Stilo > Technical | 17 | 26-11-2006 23:11 |
