| Does anybody know if the valves and pistons interfere on the 1.4 8V engine in the event of Cam Belt Failure?
| | #3 | ||
| Chasing Cars | Re: Grand Punto 1.4 8V Cam Belt Failure Hmm not sure . If its an overbore of the 1.2 rather than an extended stroke you should be ok.I can't believe you have had a cambelt snap!! . How many miles etc?
__________________ ![]() Present: 05 Punto Sporting 1.4 16v | ||
| | #4 | ||
| Shady By Name And Nature | Re: Grand Punto 1.4 8V Cam Belt Failure Didnt say belt had snapped, asked in the event off.
| | #5 | |||||
my 1.4 16v dynamic sport threw its belt when the variator went. it had only done about 9k less than 6 months old it had to be rebuilt. valves impacted the pistons. fiat rebuilt it. took 3 months for them to evently get it running right, its been ok since ... should be covered by 3 year warrenty if services were carried out
| | #6 | ||
| Re: Grand Punto 1.4 8V Cam Belt Failure The 16v and 8v are different, head-wise. The 16v, even in 1.2 form, was always an interference engine (valve/piston contact if belt breaks) whereas the 1.2 8v wasn't. I can't seem to find any technical info at the minute to confirm either way for the 1.4 8v.
| | #7 | ||
| Re: Grand Punto 1.4 8V Cam Belt Failure Well yes the 1.4 8V is a longer stroke than the 1.2 so better not assume to be safe then? I e-mailed FIAT on their help line to try to confirm, but in spite of auto message to say 'receiving attention' no actual response yet. Is their e-mail query service just a bit of window dressing?
| | #8 | |||||
| cam belt failure that isnt, but same symptoms any ideas | vauxhallfixer | Bravo / Brava | 8 | 21-02-2008 10:02 |
| Marea 1.6 cam belt failure | Joris | Marea > Technical | 8 | 17-12-2006 13:31 |
| Punto Cam Belt | snowglowjoe | Punto > Technical | 7 | 08-10-2006 18:27 |
| cam belt failure | zuluwarrior | Marea | 11 | 18-07-2006 13:47 |
| Cam Belt Failure 55 | ianp | Punto > Technical | 13 | 23-10-2005 10:50 |
