| | #16 | ||
| Unpredictable | Re: My Active Sport! Well my cars black, but im going to spray the plastic bit black to match the car because like OCZed said it looks abit off | ||
| | #17 | ||
| Re: My Active Sport! Im not too sure, as halfords sometimes arent very good at getting a correct match. I think I might get a spray place to do mine, should be a better match right.
__________________ ![]() Grande Punto Active 1.2 3dr - Crossover Black ITALIA | |||
| | #18 | ||
| TJet powaaaaaaa | Re: My Active Sport! The arch gap is stupidly big as standard on them. Putting 17's on wont help that matter either. With spraying the handles you could either take the door cards off then take the handles off, sand them, primer them and spray them then refit. Or mask them up on the car and cover the side of the car in newspaper to avoid over spray and spray them on the car if you wanted.
| | #19 | ||
| yh thats a good point. If i go to the paint shop they will strip n prime them 2 n get a proffesional finish instead of my bodge job lol how much u reckon a respray would be?
__________________ ![]() | |||
| | #20 | |||
__________________ ![]() Grande Punto Active 1.2 3dr - Crossover Black ITALIA | ||||
| | #21 | ||
| yh i was thinkin that but mine be silver so because of the black underlay the silver would be dule and darker?
| | #23 | ||
| Re: My Active Sport! Ok i wanna do a vote or a pole on that, see weva its jus a costly extra i dont need if it doesnt look that bad. will having the lower spring void warranty n tht?
| | #24 | ||
| TJet powaaaaaaa | Re: My Active Sport! sorry no my bad. Sand and prime them because if you dont sand then you will have a textured finish because of the plastice you are spraying straight onto. Sand them then plastic primer them and then let that dry and start spraying even coats and leave for an hour or so to dry and harden between coats. I think there is a guide in the mk2 section about spraying handles and mirrors. Should just be able to lift it straight from that over to the grande ones.
| | Rich_65402 | Punto | 7 | 20-05-2008 03:29 |
| | bell13 | Grande Punto | 4 | 10-10-2006 16:56 |
| | janem | Grande Punto | 3 | 26-04-2006 19:26 |
| | rich hemmings | Punto | 43 | 01-01-2006 11:44 |
| My Active Sport | specs78 | Members Motors | 36 | 03-01-2005 19:37 |
