| airbag failure light Hi all i have had my gp for two weeks now and i decided to change the headunit. As i did this and started the car up, the airbag failure light came on? Could it have anything to do with me fitting a different headunit?
| Re: airbag failure light I doubt it there is a known issue with out of date/bugged software unless you have got a bit carried away with a set of wire cutters ![]() Known faults/issues; It is recommended that the vehicle is correctly checked as this list is only intended as a guide & not applicable in all cases. Fault - Airbag light coming on at start up Cure - requires airbag ECU update Status - currently ongoing,later cars ok http://www.fiatforum.com/grande-punt...lt-issues.html Oh and welcome to the forum if you can use the search option many things that can/WILL go wrong with your punto have probably been done to death in the past | |||
| | #3 | ||
| Re: airbag failure light its only 6 months old and i didnt cut any of the original wires.
| | #4 | ||
| Re: airbag failure light I was joking about the wire cutting then again knowing what some people are capable/incapable of ![]() its a dealer job it "should" be doable whilst you wait no doubt the resident section moderator will be along at some point to give you a more accurate time scale...
__________________ What Goes Up Must Come Down..... Last edited by T14086; 07-05-2008 at 19:26. | |||
| | #5 | ||
| Grumpy Forum Moderator | Re: airbag failure light As Andy has rightly said make sure the latest airbag ECU software has been installed this should sort your problem.
| | Lawrence_16 | Stilo | 2 | 16-03-2008 14:59 |
| | tesscott6312 | Punto | 1 | 07-01-2007 01:53 |
| | willycombs | Stilo | 7 | 12-06-2006 19:57 |
| | dexys | Stilo | 16 | 10-11-2004 20:27 |
