Technical Oil / Coolant leak / turbo pipes / remap !
DEISELDAVE
Oldham
Had the car in today for some little niggles (NOT ENGINE NIGGLES) with the dealer, when i went to pick up they had sorted my problems out and then told me the coolant / oil had a leak and the turbo pipes could be loose which is why my car was making a noise ! I wasnt expecting that , didnt even know my car was making any noises or aware of any leaks . They sorted the coolant out but have re booked in to look more at the pipes , they didnt tell me exactly the problem but sounds like some pipes into the turbo were loose or about to blow off !
Hope everything is fine with it and they dont realise its remapped or i could have a problem !
Anyone else had problems like this with standard and remapped GPS mjets ?
Noticed a leak in the seal/gasket of the egr valve yesterday. Spraying a bit of coke up, not alot though. I'll take it to the dealers in the week.
have you disclosed its remapped ? wonder if the increase in power / pressure is having some part in my problems .
I was more worried about your dirty turbo :eek:, leaking exhaust gasket maybe? :(
Was it dirty? I never noticed...
It was bad wasn't it, booked in at the dealers on monday. I'll make sure I get it all sorted and give ut a proper clean myself before anything else goes on.
(thanks again mark for your help, i've put a thanks on the RR thread aswell.)
