Technical Relay diagrams
I take it your after a new relay to fool the ECU Bulb failure warning?
if so you can now get led's with built in resistors to stop this....
from http://www.piaa.co.uk/
SUPER TERA LED
LEDs, rather than conventional bulbs, are being used more and more in the automotive industry. Their low-power draw coupled with reliability and small size are all plus points for maunfacturers. PIAA believes that the fitting of LEDs is not only the domain of the new car market, as many owners are keen to swap standard bulbs with a more efficient unit. With most cars this is a simple one-for-one replacement, but for some the low-draw of an LED activates the bulb failure warning light. PIAA has now solved this problem by introducing the new Super TERA LED. Boasting an output of 6500 Kelvin, it has a built-in resistor which sends a signal to the car's electronic system to override the effect of reduced-power. Available in pairs, either as a Wedge or H6W replacement.
as for the relay chart it is in the handbook i'll try and get time to dig mine out if i get chance...
Thanks for that, didn't realise the super tera led's existed. Very expensive though!!!!
I had a look through the handbook and couldn't find the relay chart anywhere. If you find it can you give me a page number, I'll go and have another look now.
Alex
I also need to have the relay diagram or at least a list of them indicating the functions of each relay. My car has an DTC P2146 regarding on a power relay of ECU but I couldn't difeerentiate which relay is the damaged one??? If anyone could help, it'll be appreciated...:bang:
If you listen very carefully, or at a call do the stick in the ear trick, you might hear each relay energise as you turn the relevent circuit on (y)
I would like a diagram of the relays too. I can't seem to find one anywhere. Is one easily available?
me three i would like diagram. ive being reading threads to replace relay R6 for cooling fan but my haynes book says R6 without any diagram as to which relay block it is in the engine fuse box! why the fuses are labbelled and not replys i dont get. If threads have post in saying relay R6 then how do i tell which? ive looked in the fuse box and the relay have codes next to them but are different they have T codes such as T08 etc :bang:
