Has anyone else had a problem with the recent wet weather relating to the doors open warning??
As i set off from work tonight got about 100 yards and the Door open light came on (i had put my work jacket in the boot as i came out of work so thaught i cant have shut it properly.. so found a safe(ish) place to stop and envoked the local disco in the back window :idea:, and checked and all was closed, As i came home it flickered on and off more off than on as the car warmed up (knew it wasnt the door contacts as the interior light didn't come on) and by the time i got home it had gone off but came on and stayed on once i'd been in the boot again,
After reading something one here in the past about a dodgy boot latch i did a bit of investigating and warmed it with a hair drier and that solved it so i took the boot liner out and removed the latch unit and have flooded it with dewetting fluid dried that out and greased it with some special spray grease designed for electrical contactors (or something like that) and have put it back together and it works
