uh oh, here we go again
When jacking mine up I simply find anything metallic and solid to jack and stand on. Never had any problems with any car I've had. Tend to use bolted end of lower wish bone I think it is on the front and the rear swing arm and lower wish bones again for stands.
Same rear axle and bolted wishbone
Being a bit new to jacking and standing a car had anyone got a pictures of these places? Thanks
see above attachment @Sean23491
I personally don't use the sills on a post ramp. they bend to easily (sills) so i use a solid area of the for example behind wish bone and the rear arm
Nice one Superboy a quick look under my car i found the points you was talking about can see teh marks in the underseal where teh fiat dealers lifts have bit into the underseal and found a section where they have chiped a large chunk of under seal off so have smothered it in grease for now anyhow i took a couple of pictures...
http://www.flickr.com/photos/16533236@N04/1966813814/
http://www.flickr.com/photos/16533236@N04/1965989065/
I'm pretty certain they're the points that the overhead conveyor uses to carry the shell around in the factory when the car is being built. IMO they're not really designed to take the weight of the whole car complete with engine and suspension, but would probably be OK with a big enough wooden pad under them to spread the load.
I have certainly jacked the daughter's car with a trolley jack on the actual recommended jacking points (the downward-pointing flange where the three thicknesses of steel that make up the sill are spot-welded together) and they haven't bent. You do, however, chip the paint in doing so. More often, I use a block of wood on top of the jack, with the grain going ACROSS the flange, otherwise there's a danger of it splitting. I put axle stands along the sill too - as close to the jacking points as the jack will allow.
When lifting on a two post ramp, the rubber feet of the ramp go directly under the flanges too.
When lifting on a 4-post ramp with a jacking beam, I can't remember what places I have used in the past! Generally, bits of car that carry engine loads or suspension loads are a good bet (but not in the middle of the arms themselves)!
Hey Avocet.
Thanks for posting this information, really helpful.
You talk about the "(the downward-pointing flange where the three thicknesses of steel that make up the sill are spot-welded together". Do you have any pics of this area, im terrible when it comes to visualizing and want to be double sure? If you do great but if not no worries, just thought i would ask
No probs. I'll get some and post them up...
...IF my daughter ever comes home in it!
